Old 08-13-2010, 10:47 PM   #33 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Update, with pics
before I was done making the Kammbak out of coroplast the sun decided to go to bed. So I took pictures before I was 100% done. I fixed a few thing and took some more pics (lighting is not great).
First off is the lower bracket connection spot:
the brackets, I painted and clear coated them before install so that I did not have to take them back off. They are made from steel I had from my wheel skirts. Since they would be up on the glass I figured some scratch protection would be a good idea.
On the car:
Note the snow flake on the bottom:
From the inside:
After I attached the seam and after dark. I used hot glue on the whole length and a backer piece on the back half.
Tomorrow I will have to do a road test to make sure it stays on http://www.clicksmilies.com/s1106/gr...smiley-003.gif
