Old 08-13-2010, 09:22 PM   #31 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
$30 for a 4x8? Geez, I got mine for $11 per sheet.
In Reason we Trust
Old 08-13-2010, 10:00 PM   #32 (permalink)
For $30 i can get a sheet of 10mm coroplast.
Old 08-13-2010, 10:47 PM   #33 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Update, with pics
before I was done making the Kammbak out of coroplast the sun decided to go to bed. So I took pictures before I was 100% done. I fixed a few thing and took some more pics (lighting is not great).
First off is the lower bracket connection spot:
the brackets, I painted and clear coated them before install so that I did not have to take them back off. They are made from steel I had from my wheel skirts. Since they would be up on the glass I figured some scratch protection would be a good idea.
On the car:
Note the snow flake on the bottom:
From the inside:
After I attached the seam and after dark. I used hot glue on the whole length and a backer piece on the back half.
Tomorrow I will have to do a road test to make sure it stays on http://www.clicksmilies.com/s1106/gr...smiley-003.gif
Old 08-14-2010, 10:41 AM   #34 (permalink)
Wiki Mod
Testing questions:
I have seen three types of testing done.
steady state
coast down
tuft
I am not real fond of spending several hours doing steady state testing, I might but I do not see a good no wind day in the forecast.
Coast down might work, how accurate is the test?
Tuft testing would require a camera, I can use my point and shoot set to video mode but mounting would be an issue.
what would you recommend?
Old 08-14-2010, 11:57 AM   #35 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 50.97 mpg (US)
If you did some tuft testing, you could experiment with the angle of the Kammback over several runs to see how steep you can go before losing attached flow. (I have a hunch you can go a little steeper) Do you have a buddy or significant other who would be willing to drive your car while you drive a chase car with a video camera? This is the quickest, simplest way to test your mod that I know of. You don't have to drive very fast or very far to get some good data.
I use coast-down as a quick way to determine if it helps or hurts. It takes a little more time and is highly dependent on ideal (no wind) weather conditions. Looking good!
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 08-14-2010, 03:31 PM   #36 (permalink)
Wiki Mod
Testing update:
Kammback testing
start at 55mph (+ 5 winks) by cruse, hit reset on scan gauge and clutch at same spot
winds, calm to 5 MPH, E,SE coasting direction was due south
was warmed up for 30 miles first
all are feet past a mile 5280 ft +XXX ft. larger numbers are better
Start is 40 feet before an embedded survey maker end is measured off the 2ed one (exactly one mile apart)
testing done B, A, B2, A2.
Graph: (the standard deviation is added to the top of the average coast down length)
data:
It looks like my 26" (22" past original cap/ spoiler) has gained me 1.92% longer coasting distance. How does this convert to MPG?
The Following 2 Users Say Thank You to Weather Spotter For This Useful Post:
MetroMPG (08-18-2010), Piwoslaw (08-16-2010)
Old 08-14-2010, 07:29 PM   #37 (permalink)
Wiki Mod
More pics:
I painted the under side black to reduce any issue of glare (had none but it also looks better)
A look at the curve:
Back without anything on it:
Side view:
Side view 2:
back view:
Almost a top view:
As you can see I ran out of my silver paint. Another can is on order ans should be in next week.
I am still trying to figure out how to convert my 2% aerodynamic gain into a MPG savings, Ideas?
Old 08-14-2010, 10:20 PM   #38 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
Aerohead has said that a 2% aero improvement should yield 1% mpg increase.
TDi=fast frugal fun
Old 08-15-2010, 12:20 PM   #39 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
more thoughts...
Spotter, Thank you for posting your careful test data. I hope you do not find a 1% mpg increase discouraging. It is a step in the right direction. Darin (MetroMpg) has said there is no magic bullet; it's more of a magic buckshot approach, a percent or two here and a percent or two there and it all adds up.
I envy your simple and reversible construction method. I made a similar one of coroplast for testing but I don't have easy attachment holes. Do you have scraps left to make flat coroplast wheel covers? Perhaps in the future you can extend your Kammback for a longer, removable tail. I have welded up a bracket that fits in my receiver hitch for this purpose but that is as far as I have gotten so far.
TDi=fast frugal fun
Old 08-15-2010, 02:40 PM   #40 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Weather Spotter -
On the car:
I just wanted to say that re-purposing the existing shock mount holes is INGENIOUS! I love it when people figure out cool exploits like this.
CarloSW2
American Solar Energy Society
Jeep Cherokee "Aeromatics" (Kammback / partial boat tail) JeepNmpg2 Aerodynamics 74 03-10-2012 12:49 PM
Designing a partial kammback on a sedan AeroModder Aerodynamics 37 01-31-2012 09:54 PM
2009+ Honda Fit - ideal rear design for Kammback MetroMPG Aerodynamics 16 01-28-2012 03:50 PM
Kammback design trikkonceptz Aerodynamics 1 05-07-2008 07:07 PM
Partial Kammback prototype tested - preliminary results MetroMPG Aerodynamics 8 11-28-2007 09:51 AM
