Old 08-14-2010, 10:57 AM   #35 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
If you did some tuft testing, you could experiment with the angle of the Kammback over several runs to see how steep you can go before losing attached flow. (I have a hunch you can go a little steeper) Do you have a buddy or significant other who would be willing to drive your car while you drive a chase car with a video camera? This is the quickest, simplest way to test your mod that I know of. You don't have to drive very fast or very far to get some good data.
I use coast-down as a quick way to determine if it helps or hurts. It takes a little more time and is highly dependent on ideal (no wind) weather conditions. Looking good!
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
