Old 08-22-2010, 09:33 AM   #112 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Arragonis View Post
Cunning blokes Skoda - the intercooller is behind a small grill next to the right hand side (from the drivers steat) foglight. The exit is in the front wheelarch.
For those in the U.S., Skoda is part of the world's third largest car maker which includes VW, Audi and Porsche. If you click on COcyclist and look at my photos on this site you will see the left "small grill" (the horn is behind this one) blocked off with a waterproof plug for a block heater in it. I do use a little foam in the intercooler grill in subzero (Farenheit) temperatures until the engine warms up.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
