Thread: Aero hub caps
Old 08-23-2010, 04:31 PM   #22 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Update:
I did some work today and got the two front wheels covered!
How to:
Examine your existing wheels.
Buy pizza pans to fit (mine were 16" but 17" would have been better), Walmart had these for $3 each:
Locate a good spot for drilling and taping bolt holes: (in my case it was the ridge in the middle of the rim)
Drill and tap 3 holes spaced 120 degrees apart (measure with protractor). I made the holes in the pizza pans first then used that as a template for the rims. I messed up the first set of holes (they were in 1/2" to far):
Attach using bolts to that mach you tap (mine was 5/16 x18 and 1" long (.5 would have worked)):
Other side of car (notice only one set of holes):
Paint insides to slow rusting, I also put a layer of clear coat on the outside.
The Following 4 Users Say Thank You to Weather Spotter For This Useful Post:
aerohead (02-16-2011), cfg83 (08-23-2010), NeilBlanchard (08-23-2010), Soulster (08-23-2010)
