Old 08-23-2010, 03:17 AM   #21 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Soulster View Post
I would doubt that velcro would hold with the crazy bumps in Michigan's roads (they are rather crappppppy!)
That being said, the pans are only $3...so it really wouldn't hurt to try!
It's not the money, it's the risk of having them fly off.
Velcro could maybe be used as a back-up.
Old 08-23-2010, 04:31 PM   #22 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Update:
I did some work today and got the two front wheels covered!
How to:
Examine your existing wheels.
Buy pizza pans to fit (mine were 16" but 17" would have been better), Walmart had these for $3 each:
Locate a good spot for drilling and taping bolt holes: (in my case it was the ridge in the middle of the rim)
Drill and tap 3 holes spaced 120 degrees apart (measure with protractor). I made the holes in the pizza pans first then used that as a template for the rims. I messed up the first set of holes (they were in 1/2" to far):
Attach using bolts to that mach you tap (mine was 5/16 x18 and 1" long (.5 would have worked)):
Other side of car (notice only one set of holes):
Paint insides to slow rusting, I also put a layer of clear coat on the outside.
The Following 4 Users Say Thank You to Weather Spotter For This Useful Post:
aerohead (02-16-2011), cfg83 (08-23-2010), NeilBlanchard (08-23-2010), Soulster (08-23-2010)
Old 08-23-2010, 04:43 PM   #23 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Very nice!!
Old 08-23-2010, 05:04 PM   #24 (permalink)
cycleguy_GEO - '94 Geo Metro Base
90 day: 43.84 mpg (US)
They seemed to turn out pretty nice. I will be curious to see how they hold up. I have made one aero hubcap for my metro so far. I just laid some fiberglass down on top of the OEM hubcap and epoxied it up. I added some red paint to it for fun. The cap is not super smooth as I did no sanding or re-coating, but I think it will do the trick and it was both cheap and fast to do. I will see if I can post a picture later.
Old 08-23-2010, 06:10 PM   #25 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Switch to truss-head screws for a minuscule decrease in drag.
Old 08-23-2010, 06:12 PM   #26 (permalink)
Wiki Mod
Originally Posted by Patrick View Post
Switch to truss-head screws for miniscule decrease in drag. :-)
I might do that to save on/off time (can use a drill then). Do they come in galvanized?
Old 08-23-2010, 06:17 PM   #27 (permalink)
Patrick's Avatar
I think so. You might consider stainless if they're not too expensive.
Old 08-23-2010, 06:21 PM   #28 (permalink)
Wiki Mod
Himm, I see a trip to the hardware store in the making......
Old 08-23-2010, 06:27 PM   #29 (permalink)
Patrick's Avatar
I used to use button heads on my go-kart, but you need an Allen wrench to use them: 5/16-18 x 5/8 Button Socket Head Hex Drive Cap Screw (Bolt) Qty (1) [BSCS51658C] - $0.16 : NutsandBolts.com
Old 08-23-2010, 08:04 PM   #30 (permalink)
Got soul?
Soulster's Avatar
Soulster - '10 Kia Soul Plus
90 day: 35.36 mpg (US)
100k POS - '01 Dodge Neon
Did you take them back off or something? when I got back from work I didn't notice them on your car....
Commercial Aero Race Wheel covers (clear acrylic) cfg83 Aerodynamics 8 09-21-2010 12:09 AM
aero caps and wheel balancing lightning Aerodynamics 3 05-01-2009 07:54 PM
check out my taped hub caps! modmonster Aerodynamics 9 01-17-2009 11:45 PM
"Pizza pan" hub caps (2008 Civic)? KJSatz Aerodynamics 2 08-05-2008 01:14 AM
Pruis Pizza Pan Hub Caps.... justpassntime Aerodynamics 1 07-14-2008 10:55 AM
