Old 08-28-2010, 10:15 PM   #53 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Originally Posted by Patrick View Post
Also, if the actuator rod is not too brittle, you might be able to bend an "S" shape into it at the point where it would fit into the vent bar. Make sure the hole in the vent bar is large enough for the rod to go through, then snake the rod into the hole before inserting the whole assembly into the car. Make sure the horizontal part of the rod stays in the vent bar hole while installing. Lots of carburetor actuator rods were set up this way - there was nothing else holding the rods into the arms.
I could do that, the actuator end has a 90 in it and then a wide spot to hold it from coming out.
I might make it in two pieces, with the clamp to hook them together then I do not have to remove a lot to get it to work.
miket:
the slider is thin, touches the grate, and is not held to the grate by much. I think the epoxy held but that the actuator has a 3/4 to 1" travel, the grate has .5-.6. I think the actuator just pushed passed the end of travel on the slider and side loaded the epoxy too far.
What is a clamptite?
