Old 08-29-2010, 01:29 PM   #54 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
well I do not think this will work, I could get it hooked up, but it would be a hassle. The other issue is that I need it open most of the time and the current set up the default is closed. The actuators do not have any hold force when the power is removed. So I would need to come up with a spring set up or a lock mechanism to hold it open.
All this work for a faster warm up?
I might try some slots, with a 3/4" travel I can make some nice slots. This would still have 1/2 of the flow blocked but I might make a bypass area.
Ideas?
