Old 08-29-2010, 05:53 PM   #58 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Update:
I got myself a movable grill block!
On the car:
Closed:
Open:
I took the easy way out and made a sliding grill block. I compromised and just replaced the grates with the slider. It is still stealth
The OEM grill has an opening of 94 sq". Mine has about 75 sq" or 80% of OEM I did this by keeping it back and then I can make it taller than the OEM one. It is also wider by 3 ".
How I made it:
I cut some colorplast to the size I wanted. I measured the actuation length to be .75" so that is how wide I made the slats. I marked them all out before cutting:
One cut out:
and #2:
I cut some slots for bolts and put the bolts in. I saw that I needed spacers on the back side:
Assembled open:
Closed:
Once I put it on I found that I had too much play in the pices (away from each other). So I made some brackets to allow sliding but not in and out from air pressure:
On the car:
I just used the clamps for now, I will likely epoxy in on but for testing and my trip tomorrow this should work. The actuator and mounts are just hot glued onto the colorplast.
I still need to paint it but I can do that after my trip.
What do you think?
