Old 08-30-2010, 07:04 AM   #12 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Arragonis View Post
I thought when the Diesel cut off is used the fuel system would need bleeding to restart, at least that is what the (untrusted) Skoda dealer told me.
Bleeding off air is automatic in some new diesels. I have a hand pump... But my instruction manual says that bleeding is required only if the engine stops because of an empty tank ("then fill up at least 5 liters and pump the air out").
I've been googling frantically and the lack of information suggests that my ultra-hi-tech 1.6HDi does not have a fuel cutoff solenoid. Instead, my guess is that in commonrails the injectors are killed, which should have the same effect. A solenoid was needed in older diesels with distributor pumps running right off the engine.
