Old 08-29-2010, 12:42 PM   #11 (permalink)
The PRC.
Denis - I was being silly, apologies. I followed the pics just fine.
Now if I was brave enough to try this....
One thought did cross my mind this afternoon (doing the weekly shop, my life is so rich ). I thought when the Diesel cut off is used the fuel system would need bleeding to restart, at least that is what the (untrusted) Skoda dealer told me.
Old 08-30-2010, 07:04 AM   #12 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Bleeding off air is automatic in some new diesels. I have a hand pump... But my instruction manual says that bleeding is required only if the engine stops because of an empty tank ("then fill up at least 5 liters and pump the air out").
I've been googling frantically and the lack of information suggests that my ultra-hi-tech 1.6HDi does not have a fuel cutoff solenoid. Instead, my guess is that in commonrails the injectors are killed, which should have the same effect. A solenoid was needed in older diesels with distributor pumps running right off the engine.
Old 11-02-2010, 10:13 AM   #13 (permalink)
aero guerrilla
Piwoslaw's Avatar
OK, it turns out what I thought was my crankshaft position sensor was not, and after finding the real sensor I have an engine kill button (wired to the mom-off-mom button I use for engine starting).
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
Fuel injector kill switch for '05 Scion xB The Fridge DIY / How-to 21 09-24-2010 03:37 PM
The First Three Diesel Passenger Cars Laurentiu The Lounge 0 07-03-2010 09:40 AM
Chrysler Expected To Kill Models, Bring Italian Vehicles Ashore Jammer The Lounge 17 06-26-2010 07:29 PM
Dodge Shadow/Plymouth Sundance Kill switch how-to bkruger DIY / How-to 0 10-30-2009 10:55 AM
