Old 08-30-2010, 02:07 PM   #98 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I used Superbright LED multidirectional bulbs for my brake lights to replace the stock bulbs when I did the VW 5 brake light mod. They seem very similar to stock brightness. I didn't change the turn signal bulbs because I didn't want to mess with adding resistors to keep the car from mistaking them for a burnt out bulb or blinking too fast. Do you plan to reuse the stock Insight taillight housings? If you are adding side marker housings it shouldn't be a problem to use LED. I have LED "marker lights" in my grill as Daytime Running Lights.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
