civic-man, that ecu is not correct. Do you have the correct one? vacuum lines should be indicated in the fuel and emissions pdf... probably the same whether 96 or 99 version but i'm not sure. As for the intake manifold it looks to be right. egr wiring should be shown in the wiring diagram pdf. You need to know which ecu you are using to tell how the stuff all goes together. I would guess you are using the P2J-003? If you aren't using the correct ecu I don't know how it could work properly or how to wire it.
