Old 09-14-2010, 12:23 AM   #2 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Meph,
not sure where to begin......
How about you giver us enough info to make a decission????
For starters, how about the last number on the tire size???
it's kinda important.......
The car came stock with 205/60/14. they wiegh 19lbs and have a diameter of 23.8 inches.
THere is no 285 in a 14, 15, or 16 (at tirerack.com so I can only assume they are 17 inch??????
I 285/40/17 wieghs 30lbs. that is just the tire!!!!! so you have 11lbs X 4 spinning on each corner 44extra lbs.
the diameter is 26inches.
Again, I assume you are staying with 17 inch rims to runn the 225/50/17. they wiegh 31lbs.....1lb more or 48 extra lbs from stock spinning. They are 25.9ijnches in diameter.....why bother????? the only upside is the high sidewall "COULD" give a little softer ride.
Bottom line .....you will not get better mileage.
225/50/17 wieghs more and the profile is 9.5inches down from 11inches.
more info needed....
good luck
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
