Old 09-21-2010, 08:57 PM   #101 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Update:
I did some rearranging work so that I can reverse the grates back to my original set up. I left the 2x2 on the bottom (ran it the whole way across both grates), and used the same mounting setup for the actuators as in the test run. I just duplicated it for the second one.
From this set up:
All I modified is adding nylon washers on each side of the "L" bracket, a 1x1 on the bottom side of the 2x2 (radiator side) to allow the actuators room to move.
I mounted it up:
I tested it out (last time I had the main epoxy connection break) nothing broke this time!
Then I took it for a test spin to test these things:
1 will the grates stay open at speed. Passed
2. stay closed at speed. Passed
3 will close at speed. Passed
4. will open at speed. Passed
I tested it up to 55MPH and over paved and gravel roads. Total test run 5 miles.
It will get a much better test the next time I go into town.
The Following User Says Thank You to Weather Spotter For This Useful Post:
WesternStarSCR (10-11-2012)
