Old 09-22-2010, 09:27 PM   #968 (permalink)
cmj
Honda - '96 Honda Civic EX
90 day: 36.12 mpg (US)
Originally Posted by dcb View Post
Ok, thx, I think you need a 20mhz crystal plus some other hardware changes if you want to use the latest cpp file without making any code changes.
If starting from an arduino, there is an archived version of the original arduino code here (which probably needs an archived version of arduino ide):
http://opengauge.googlecode.com/svn/...no/mpguino.pde
My first test was not a successful one. Quick jaunt to the Taco Bell for some dinner, and the MPGuino's data log looks all wonky.
Here's the setup
96 Civic EX - Automatic and Stock
VSS wire - C18 (Blue/White)
INJ1 wire - A04 (Brown)
Breadboard is wired with 22AWG single strand
VSS and INJ wire are 18AWG multi strand
VSS/Pulse Mile - 8208ul
MicroSec/Gallon - 0272500000ul
InjectorDelayuS - 72ul
These settings were taken from a 97 DX Coupe Auto (Wiki)
The following is the data collected. I pulled out a section where I was doing 40mph consistently on flat road.
0.55 1.01 13804 6 3
1.52 4.05 14860 5 5
2.56 7.86 20504 6 9
2.09 7.96 28220 7 10
1.72 8.15 28280 6 7
1.18 7.03 44088 8 10
1.64 10 38044 7 9
1.45 8.9 43656 8 12
1.42 8.63 37788 7 9
1.44 7.42 37864 8 9
1.74 7.85 30876 7 9
1.72 7.8 31076 7 9
1.58 6.89 30332 7 8
1.54 5.94 23524 6 5
1.35 5.1 27232 7 7
Can anyone see any discrepancies?
Power/Ground is soley from my laptop to the arduino. Is this an issue? I figure no since i'm not requiring power for anything other than processing. I just don't know if the lack of chassis ground is my issue.
