Old 09-27-2010, 06:09 PM   #2 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I have a Mk IV VW Golf but it is a similar color, does that count? I also use the pipe insulation grill block. I painted my blue grill bars black and stuffed the insulation between the grill bars from the front. It's pretty stealth too. The upper grill has been blocked year round for 3 years. In winter I split the insulation and push it over the 1 or 2 of the lower grill bars too.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
