Old 09-25-2010, 01:05 PM   #1 (permalink)
Semi-stealth Golf/Vento grill
I used some pipe insulation cut in half and wedged it in the back of the grill. It seems pretty sturdy and airtight, and is not that noticeable, even with it being bright grey.
I took it down a fast bumpy road to see if anything would fall out, and the car seemed to warm up slightly quicker (but this may have just been a placebo).
Anyway, pictures!
From Behind:
Installed:
and from a distance:
I admit it's not as impressive as most things on here, I just wanted something that wouldn't damage the car and was easily removeable.
Next up is to paint it and seal off the bottom too.
Anyone else driving a similar VW?
Old 09-27-2010, 07:09 PM   #2 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I have a Mk IV VW Golf but it is a similar color, does that count? I also use the pipe insulation grill block. I painted my blue grill bars black and stuffed the insulation between the grill bars from the front. It's pretty stealth too. The upper grill has been blocked year round for 3 years. In winter I split the insulation and push it over the 1 or 2 of the lower grill bars too.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 09-27-2010, 09:14 PM   #3 (permalink)
Zerohour's Avatar
Pooparu - '01 Subaru Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Chevy Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '11 Mini Cooper
90 day: 37.63 mpg (US)
Gramps - '95 Subaru Legacy Postal
90 day: 23.18 mpg (US)
If that works for you and you're than interested in making a more permanent structure - I would seek out some black ABS plastic. Or even a square plastic office garbage can. Cut it down to shape and use some basic 2-part epoxy.
Pretty straight forward way how you did it! Any other eco-mods in the future?
Old 09-27-2010, 09:51 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Buxtonski -
Pretty neat. I like that you have the choice of treating each gap in your VW grill separately. I have done big long pipe-chunks that cover a whole row, but with pieces you can add/remove as needed. It looks like you have 9 chunks on each side of the VW badge for 18 total. Each chunk gives you control of 5.5% of the total grill opening per chunk.
CarloSW2
American Solar Energy Society
Old 09-28-2010, 03:52 AM   #5 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
I've just applied a rough tank tape out block to my '96 polo once I'm happy with the temps I think I'll take your lead with the insulation idea!
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 09-30-2010, 08:11 PM   #6 (permalink)
Thanks guys
Thanks, I've found a laminated piece of chipboard, looks like the back of a bookcase, I'm going to paint it black and put it under the front bumper (there's a large gap from bumper to radiator). I'm not sure how aero improving this will be, since the front bib has a extended lip that goes down further than the bottom of most of the bumper, but it couldn't hurt!
I need to block off the other intakes too, I just need to find something very reversible (car will be sold on).
Go for it man! I decided against tape (like a few other guys have) since it's not gonna last against rain.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 10:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 01:31 AM
Grill Block Summary 4536 Aerodynamics 19 07-22-2010 12:55 PM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 07:00 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 04:09 PM
