Old 12-11-2007, 03:26 PM   #11 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Do you have A/C? It could be coming on as part of the defrost setting. And you'd definitely feel the A/C kicking in.
For sure it's not the A/C -- when that engages, the clutch is quite loud and there's a considerable loss of available power. I've tested the situation with any possible heat/air in the off position and the air selector to "vent". It requires the A/C button to be engaged as well. I tried the A/C during this condition and it was more pronounced than the mystery condition.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
