Old 10-14-2010, 05:30 PM   #13 (permalink)
NachtRitter
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Originally Posted by crexcrex View Post
pull side mirror, grind or use forty grit sand paper, fill with short strand fiberglass or bondo sand to doors contour, prime n paint looks stock................your method is tedious and the blank you installed is not flush and has gaps that will allow water and air to enter, plus drag prone...............
you wanted a opinion.................crexcrex
crexcrex... Could you please provide a link to your step-by-step instructions along with sources and pix? Where to get short strand FG and why use it instead of other stuff? How would your method be less tedious than k.civic.f4i's method? Why would your method work better than k.civic.f4i's (Does a mounted mirror allow water and air to enter??)?
If you don't already have a link, could you create a thread with the info?
Thx!
