Originally Posted by aerohead
Would you be willing to share data regarding your pre-test operation,test site,number of back-to-back runs,meteorological data,velocity profile,scatter-plot of data points,timing resolution,velocity capture resolution?
X2
On my testing ANY winds drastically changed the results. Also I did not seen much time diff from 60 down to 30 so I coasted to a stop and marked the distance. That is where the changes started showing up.
We are here to help, so the more data you give the better help we can provide
