Old 10-16-2010, 02:07 PM   #21 (permalink)
effect
It's quite possible that the skirts are lowering drag while variability in test conditions are cloaking the difference within the bandwidth of your signal-to-noise ratio.
A simple tape and yarn tuft test can indicate flow quality over the skirts.
If the yarn is oriented straight back your skirts are doing their job.
Old 10-16-2010, 02:13 PM   #22 (permalink)
1. Good luck seeing yarn at night, 2. There is no variability in conditions, as my tests were one right after another.
Old 10-16-2010, 02:20 PM   #23 (permalink)
Eco Amateur
AeroCav - '03 Chevrolet Cavalier
Originally Posted by cfg83 View Post
Old Tele man -
Yeah, I like to say that well-designed aero-mods help all of the time, but the magnitude is, as you say, greatly diminished and/or undetectable at low speeds (but it's still there). The best-case scenario is that it "all adds up".
CarloSW2
While I agree with your logic, I have to argue the cost variable.
If a set of skirts cost me 10-20 dollars and don't pay for themselves through fuel savings... then I'm still out 10-20 bucks for nothing but questionable stares and looks at my car going up the highway.
Now if they work, and I can break even, then they are worth the expense and trouble.
AeroCav
Current Mods: Deleted mudflaps, Denso TT plugs, Synthetic blend motor oil
Future: Aero rim covers, air dam, grill block, full synthetic oil, synthetic transmission oil, reas wheel skirts, partial camback
Old 10-16-2010, 03:30 PM   #24 (permalink)
conditions
Would you be willing to share data regarding your pre-test operation,test site,number of back-to-back runs,meteorological data,velocity profile,scatter-plot of data points,timing resolution,velocity capture resolution?
Old 10-16-2010, 05:08 PM   #25 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
X2
On my testing ANY winds drastically changed the results. Also I did not seen much time diff from 60 down to 30 so I coasted to a stop and marked the distance. That is where the changes started showing up.
We are here to help, so the more data you give the better help we can provide
Old 10-16-2010, 10:53 PM   #26 (permalink)
I gave you all the data I have
Old 10-16-2010, 11:20 PM   #27 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I would agree that wind plays more of a factor than any other factor except driving ability. Work on the front and make it as laminar as possible before worrying about the rear part of you vehicle. Wind hits the front part of the vehicle first and should be quelled before worrying about what happens after.
Noah Webster, 1787
Old 10-16-2010, 11:55 PM   #28 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
How about during the day time?
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 10-17-2010, 04:50 AM   #29 (permalink)
I already get police following me at night with these on, no way am I doing this during the day. I said I already plan on mocking both front and rear up together, but I need to finish the brackets up and make up the temporary pieces for the fairings. The permanents will be sheet aluminum I will take pictures of this when I mock it all up again.
Old 10-18-2010, 07:38 PM   #30 (permalink)
...beats walking...
Originally Posted by miket View Post
As an honorary scotsman im going to call mine wheel kilts.
..."Dulce Periculum" from near Ardencaple.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 10:16 AM
Front Wheel Skirts; 1950 Nash Ambassador Rokeby Aerodynamics 18 04-06-2014 01:14 PM
lowering and/or wheel skirts dmac257 Aerodynamics 4 08-16-2010 02:09 PM
2000 Mazda Protege Rear Wheel skirts Walk Through Blue Bomber Man Aerodynamics 13 08-29-2009 03:12 AM
Wheel skirts slowing me down? wagonman76 Aerodynamics 11 07-20-2009 01:41 PM
