Do you believe that Global Climate Change is real, and that it is caused by humans?
If you do not believe in the Theory of Gravity, will you float away?
No I have not seen the hard facts global temp (non "adjusted" numbers) over a long enough time span to say that the earth is warming beyond it's normal cycles.
When the data gives me 500-1000 years of reliable info then I can look at the graph and draw conclusions. What will I see on this graph? lots of ups and downs, some larger than others but I will see cycles like, 30, 100, 500, 1500 yr ect.
Tell me now which one we are in?
Why did 30-40 yr ago people get freaked out about global cooing?
These people who believe we are killing earth have a funny way of looking at change. if Evolution is true (not in my Book, the Bible) then you have a 4-5 Billion year old planet so I need to see 1 Billion years of data
What, you do not have that?
Ok, tell me this, is the earth not just evolving into something different?
Why stop progress?
Why should I lower my standard of living to fix some tree hugging person's guilt attack? It seems that no mater what there is another massive problem to fix or we will all die (global cooling, ozone hole, global warming, whats next?).
Believe what you want to but DO NOT force me to change for your belief. debate me in the area of hard facts and win me over.
