Originally Posted by jjackstone
I was also wondering where they came up with the 31 cent per kwh number. I have PGE in Sacramento and even with taxes only pay about 17 cents/kwh. I suppose the prices could be close to double in the LA area, but the number seems pretty inflated.
JJ
The answer is simple: they're morons. They probably charged off a standard meter and got hit for the highest peak-hours tier. Southern California Edison charges between 4 and 11 cents per kWh for "super off-peak" EV charging (midnight-6am) when sharing the household meter. If you have a separate meter put in, you get 14 cents peak and 6 cents off-peak (off-peak being 9pm to noon the following day.)
