Old 04-18-2008, 03:09 PM   #18 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by AndrewJ View Post
Rick, It's my understanding that if you disrupt any of the ECU's info about the position of a rotating part (here I mean engine part like crank angle sensor, TDC sensor, rotor sensor, etc) then the ECU is not gonna get "confused" it's just going to, for saftey's sake, default to killing the engine.
The trick is to do it without throwing a code/CEL.
That being said, I think you're on the right track with the +12v-Ignition thing.
I guess the only way to know for sure is to cut the wire
You could always just solder it back together if it doesn't work right?
Let me know if you find something that works.
Your integra's wiring should be pretty much identical to my civic's (and preludes for that matter)
Well, you were exactly right. It threw a Crankshaft Position Sensor fault code.
I had the distributor apart, took pix, documented the process, wired it up, and nothing happened
Ah, it's all good -- I don't EOC that much anyway, I was hoping it was an easy fix if people needed it.
It wouldn't start with the wire disconnected, but it ran with the switch flipped
Oh well, I guess the best bet is to cut the injectors and reset it with the SG.
RH77
BTW, how do you know if your cap and rotor are worn? Seems like an easy install...
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
