Old 04-19-2008, 12:10 AM   #25 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
Originally Posted by Compaq888 View Post
1. It does immediatly kill the engine because I have pressed the gas after and there is no noise and the scangauge goes dead...
May work for you...
But I definitely have some sputtering issues sometimes after killing the fuel pump.
Makes sense, kill the pressure in the fuel line and there'll still be some residual pressure in the lines that will have to be released by the injectors. Resulting in injectors firing after the switch is thrown. More so if the gas pedal isn't depressed (engine idling) when the switch is thrown.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
