Old 04-20-2008, 03:38 AM   #18 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by trebuchet03 View Post
I wish I knew someone that owned a minivan... It probably would fit - the dimensions are 44"H x 35"W x 98"L With the back seat removed - it should totally fit.... It's just finding one - renting is just way too expensive compared to the truck option at the moment...
When I first started working my current job, I was under 25 -- so the solution was Enterprise and a corporate waiver. Minivans generally come at a premium, but can be rented from 18-25 y/o. Can you get a statement from your sponsor(s) as a "Corporate Representative"? Sometimes that's all it takes to waive the age requirement. Other agencies may honor the same waiver.
A Mini-Van may be the solution. How many passengers?
Also, one-way rentals are killer expensive. If someone can drive the vehicle back, the extra time will offset the premium.
-R
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
