Originally Posted by bobski
Right. I was ruling out special-purpose pins like rx(0), tx(1) and I seem to recall the pin with an attached on-board LED having something to do with programming, but I see now that's pin 13 which is in use by the LCD. So yeah, there's two digital pins.
well, all the pins I listed can be used as general i/o digital pins, so technically there are 6 available. You might want to avoid rx so as to have an easier time with the bootloader.
My line of thought on the analog side was that if we relocate the button signals to different analog pins, then use analog 4 and 5 for I2C, all the analog inputs will be occupied.
FYI, with a couple resistors you can "multiplex" several buttons onto one analog pin. It's how the buttons on my saturns cruise control works.
http://i13.tinypic.com/80uib5y.jpg
Which is great as a finished product but it doesn't leave any room for expansion, tinkering or innovation in general.
I think that really depends on the tinkerer. I'm reminded of brandonU's powning of a usb cable, though the writeup is gone now:
http://ecomodder.com/forum/showthrea...html#post37599 , basically, if you can see or hack your way to the leads, you can tinker/expand/modify/innovate anything, just not in lego fashion.
Doing what the OP was requesting, adding logging, means adding one wire to the unit (3 if you want to borrow 5 volts and ground).
They sound awesome but I doubt the Arduino IDE supports them (in spite of them sharing AVR architecture), and I don't like the thought of programming serial comms in assembly.
There are arduino options there, as well as possibly taking a dremel to a mega 328
Arduino Forum - sizing down my arduino
