Old 12-12-2010, 10:08 PM   #28 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
I was reading metrompg's thread on coolant-heating block heaters.
http://ecomodder.com/forum/showthrea...-warm-817.html
Even with an 800 watt heater it took an hour to warm the 1 liter (approx) engine from 30 deg. F to 123-146 deg. F, depending on whether or not he idled the engine briefly every 15 minutes during the heatup.
So - while I'm still planning on getting a 125W stick-on oil pan heater, and maybe a 50-75 watt additional one to put on a second flat spot on the oil pan, I'm beginning to wonder how much help these little heaters can give us. OK, if your engine is bigger you can use a 250-350W oil pan heater but that's still nowhere near the output of the 800W one he used in the Metro.
I still want to try it. Next step, to tell the good wife that I'm going to spend about $75 on my FE obsession...
Coast long and prosper.
