Old 01-11-2011, 01:35 PM   #129 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Originally Posted by JasonG View Post
Nice work WS !
How did you fix the tail to car gaps ?
I was going to suggest placing painters plastic on the car and using can foam. If it was done before fiberglassing it would bond better but should stick to the fiberglass well enough.
For now I used tape. I might fill in the gapes with foam puddy or bondo next time I take off the tail. I would rather not take it off if I can help it. I thought of using a spray foam but I think that it will keep expanding longer than I want. I might use it though to make the shape, then fiberglass it. For now the tape works. When it warms up I will work on it more.
