Originally Posted by BamZipPow
Then you need to be creative...
You could set up a center point (nail) and use a strip of wood with a hole at one end and a blade set into the other end. Set the pan onto the nail and place the wood strip over the nail withe the blade towards the pan. Make multiple passes to make a clean cut. Take yer time...yer not in a race.
Pretty much what I did... Put a nail in the center, tied a string to the nail, then tied the other end of the string to a dremel tool... wasn't perfect but worked reasonably well.
