Originally Posted by sid
I wish he would have tested the conventional topper with rear garnish, because that is what I have. The top slopes 10 degrees (restricted by door opening) and the sides slope in 12 degrees. The "garnishes" extend 5 inches beyond the back of the topper, so that they are about even with the end of the bumper.
You might need something that can slide or lift out of the way when you need access to the rear doors...
