Old 01-24-2011, 05:55 PM   #21 (permalink)
...beats walking...
Originally Posted by t vago View Post
What are these "crosswinds" of which you speak? Is that some dadgum furriner word?
...in the Navy, that'd be a euphemism for "deadly pharts."
Old 01-24-2011, 09:23 PM   #22 (permalink)
sid
grayranger - '10 Ford Ranger XL 2 door supercab
90 day: 30.64 mpg (US)
I wish he would have tested the conventional topper with rear garnish, because that is what I have. The top slopes 10 degrees (restricted by door opening) and the sides slope in 12 degrees. The "garnishes" extend 5 inches beyond the back of the topper, so that they are about even with the end of the bumper.
2010 Ford Ranger, extra cab, 2.3 liter
http://www.stonemarmot.com
Band's latest song/music video "I Sing Along"
Old 01-24-2011, 11:31 PM   #23 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
You might need something that can slide or lift out of the way when you need access to the rear doors...
Old 01-27-2011, 10:11 PM   #24 (permalink)
sid
No, the rear doors barely clear the top garnish. The photo is slightly looking down on the back of the truck, which gives the perception that the doors are too tall. Clearing the doors is the reason the top garnish is only 10 degrees and not 12 degrees like on the sides.
Old 01-28-2011, 09:32 AM   #25 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
The utility of your cap cannot be beat. Especially if both doors open wide enough to carry full 4x8 sheets of plywood, drywall, etc.
From your pix it looks like your garnish does not have any blend radius between approach and tapers. If so, they don't help aero. They may help keep the rear doors cleaner and drier though.
Recreation Engineer
Old 01-28-2011, 09:55 AM   #26 (permalink)
Sid
You could attach piano hinges connected to the top and sides to extend and or change the angle of the garnish. Then simply fold back to gain entrance.
By using this method you could create a full folding Kamaback if you wanted to.
Old 01-29-2011, 10:41 PM   #27 (permalink)
sid
No, it doesn't have a lot of bend radius. I tried to radius it as much as I could, but I also had to make sure I still maintained some glue attachment surface for the side and top panels to the frame of the topper. That limited how much radius I could add. Besides, I don't think the garnishes in the report were attached with any significant radius.
Also, the opening is only about 39 inches wide. Not big enough for a full sheet of plywood, but big enough for most organs and all the amps and speaker cabinets I typically carry.
