Originally Posted by MetroMPG
Looks about right.
And... suggests the final curvature of your existing lines can be a little steeper to match the template.
I should be able to pull the tape and 4 screws and drop the shim fer the center spar and then rescrew the 4 screws back in then retape...
I'll have to remove the rear window in the process and might have to recut it...
