Old 01-25-2011, 01:40 AM   #91 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Finally found some software that I could use to merge the template over my T-100...
I ended up using Merge which is freeware.
I had to git creative on cropping and straightening my photo until I got it straight and lined up. Then I used the scaling within Merge to git it lined up.
Old 01-25-2011, 08:41 AM   #92 (permalink)
90 day: 51.82 mpg (US)
The template should be sized (apparently) so your tires share the same ground plane as the aero car in the drawing.
(I'm not sure it's strictly correct for very large vehicles, but that's another discussion.)
Old 01-25-2011, 11:23 AM   #93 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Old 01-25-2011, 11:45 AM   #94 (permalink)
Looks about right.
And... suggests the final curvature of your existing lines can be a little steeper to match the template.
Old 01-25-2011, 11:47 AM   #95 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Talking
Looks about right.
I should be able to pull the tape and 4 screws and drop the shim fer the center spar and then rescrew the 4 screws back in then retape...
I'll have to remove the rear window in the process and might have to recut it...
Old 01-25-2011, 12:07 PM   #96 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
This is the approximation of where the boattail would end based on the template...
So about 8' further from the end of the truck.
Old 01-25-2011, 05:39 PM   #97 (permalink)
80%
BZP, you can chop it off at 80% of the template without any measurable drag increase ( you'll have a 'phantom tail' there in the void ),and it will give you space for lights,signals, and license plate.
BamZipPow (01-25-2011), HHOTDI (06-08-2014)
Old 01-25-2011, 06:08 PM   #98 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
I was thinking about making a boattail out of...pool noodles!
Old 01-25-2011, 09:38 PM   #99 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Spent a few hours today tracing over aerohead's template in OpenOffice Draw...
Here's how I overlayed the template...
Paste the big photo in the master layer and close the master layer.
Resize the grouped template until the template matches up to the top of the roof and the bottom of the tires (maintaining the proper ratio by holding down the shift key while resizing).
Export it as a jpg file.
If you want the OpenOffice Draw file...send me a PM.
Old 01-25-2011, 11:02 PM   #100 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Talking
Put the template in my album in png format...
The Following User Says Thank You to BamZipPow For This Useful Post:
NeilBlanchard (01-25-2011)
found another aero cap AeroAl Aerodynamics 5 05-19-2011 12:00 PM
Truck Aero, Bed cover DIY tonneau? Chris D. Aerodynamics 84 11-04-2010 11:56 PM
CLASS - 8 Truck Streamlining Benchmark aerohead Aerodynamics 0 02-28-2009 03:17 PM
CLASS-8 Truck Streamlining / Fuel Economy ( Part-1 ) Aero Specifics aerohead Aerodynamics 1 02-23-2009 05:16 PM
Yet Another Pickup Truck Aero Idea Big Dave Aerodynamics 14 05-03-2008 03:17 PM
