Old 02-17-2011, 03:27 PM   #67 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by G2TDI View Post
What material is your bottom cover?
It is a salvaged political sign- 4'x8'. I keep meaning to start a thread but I do have the photos uploaded in my albums. If you click on COcyclist above my avatar it should take you to my page and the albums are down on the right. I have one marked "belly pan". I hope this helps. I found you on tdiclub the other day before the server went down. I will be following you there as well.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
