Old 03-02-2011, 12:50 PM   #101 (permalink)
darcane
darcane's Avatar
Originally Posted by nimblemotors View Post
This container was for industrial hazardous solvent use, not a milk carton.
No existing tank was this size or shape and if you look, there is no room for anything but this exact size, which already is quite small.
If you look at race tanks, they are not designed for in-tank EFI pumps,
nor for filler tubes, so they just don't work here.
OK, you're probably good as far as the material goes then. I just wanted to make sure it was something you had considered first.
Technically speaking, your tank wasn't designed for an in-tank EFI pump nor filler tube either. However, there are aftermarket tanks allow for filler necks and fuel level sending units, and having a separate pump shouldn't be a reason to be unsafe, especially with something as critical as a fuel tank.
I'd just say, keep a real close eye on it and be prepared to find a different location if it becomes a problem.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
