Old 03-14-2011, 05:43 PM   #17 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
BamZipPow -
Originally Posted by BamZipPow View Post
Mustache only made it through one tank before it got "lost"...
However on the other side of it...got my best ever from Houston to Ardmore...26.98mpg! This run is usually around 21-23mpg.
So now I have this crazy idea fer an adjustable air dam. Something that I can pivot down fer highway speeds but allow it to bump up when it comes to obstacles. I might use another noodle fer the test material but eventually move on to something longer and durable.
I did something similar to that in my coroplast grill block :
http://ecomodder.com/forum/showthrea...lock-7603.html
However, I have since removed the grill block and have a two-piece spring mounted air dam.
Benefits :
- Robust failure. If the air-dam hits something, the zip-tie that connects the air-dam to the spring breaks and the air-dam just swings back. Replace the zip-tie and I'm off and running.
- No maintenance. Other than zip-tie replacement, it's set it and forget it.
Problems :
- A jack of one trade solution. For every spring there is an MPH where the spring will hold the air-dam at a vertical position in relation to the air stream. At lower MPH it will be angled into the air-stream. This might not be bad, but it would allow more air under the car. At a higher MPH it will be angled in the same directon as the air stream. Soooooo, you need to find the perfect spring for your needs.
- Stability of air-dam. Others have told me that my grill-block would be too unstable. When I did my video, you can see that it does wobble, but the "average" relationship to the air stream is stable. If you are in steady-state MPH, the grill-block maintains the same relationship to the air stream. With that said, I have seen the air-dam become more unstable when I am following a big truck because the air stream is turbulent.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
BamZipPow (03-14-2011)
