Originally Posted by johnlvs2run
Then I pull out the black wire (with pliers) and insert the wires for the k/switch, yes?
How can the k/switch be routed through the base of the shifter?
YES.
To route the wire through the base of the shifter is going to require you to remove the that whole cover. (the one with the cup holders and the shifter. From what I can see from interior pics online, its only a matter of 2-3 screws on both sides of the cover) But i don't own the car, so its pure speculation.
