Why are we talking about mods in the driving technique thread?
Originally Posted by Kodak
As far as the parking is concerned, the extended glide may help your mpg ratio for that trip; however on the way back it will create extra ground to cover. If less gas is the goal, then the answer is clear.
Aha - but the tip suggests "orbiting" a parking area. So the landing spot isn't necessarily any further away.
This tip sure gets people commenting. I need to put an asterisk beside it:
* "This tip is mostly useless, but also mostly harmless. It doesn't actually save fuel. It's a band-aid that only serves to slightly goose your MPG numbers in those rare cases where you overcook it and come into a parking situation with too much momentum. Next time, pay attention, bonehead, and don't use more fuel than you have to in the first place. ."
