Old 04-04-2011, 11:19 PM   #12 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Originally Posted by twelvevoltman View Post
First off, do you have to hold the button in for it to work?
It really depends on the kind of switch you are using. Generally, with a flipping switch, you just flick it off, then flick it on. If you have a push button switch, it still depends on what kind you have. Some require you to push once (to turn off), push again (to turn on). Some require you to push and hold (off), then release (on).
So it really depends.
Where is a good mounting location for the switch? I looked at shift knobs with a built in 12v switch.
Whatever is convenient for you. I just have mine sitting next to my shifter. You may also want to consider putting it somewhere you can easily access it, yet at the same time, NOT accidentally activate it.
When you removed your side mirror did you do just the pass. side or both? Also, what did you do, if anything, for rear visibility and to cover the holes left from the removal?
I removed both driver and passenger side mirrors. In its place, i used a big 4" blind spot mirror mounted on the inside of my driver side door. For rear visability, i used a Convexed wide-angle mirror
Amazon.com: Razo RG22 11.8" Black Frame Wide Angle Flat Rear View Mirror - Pack of 1: Automotive
To cover the holes, i just wedged a piece of coroplast in the opening left by the mirror removal.
Yes, yes yes, removing your side mirrors is illegal in some states. I've been driving mirrorless for over a year and i live next to the police department, so I drive by cops EVERYDAY, they never even notice my missing mirrors. If anything, they notice my wheel skirts more.
And when they do notice my skirts, they point and laugh.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
