Thread: Ultra Lean
Old 04-20-2011, 03:16 PM   #44 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by richard_lyew View Post
thanks. i will buy one and install it down stream from the AFC to get the changed reading.
Thanks again man
FYI, a ScanGauge -- or any OBDII based MPG meter -- won't work reliably on a lean burn system (because it extrapolates fuel consumption from air consumption at stoich, plus additional allowances for open loop).
You will need to use an MPGuino or equivalent if you want to know fuel consumption while fiddling with A/F ratios.
