On the TDI, you don't even take a look at the filter to see if you need to change it as they have one time compressible seals. Once you open that airbox, it's too late to turn back.
Originally Posted by trikkonceptz
There is only one draw back to using K&N filters or re-usable filters that require oil. And that is the oil. If improperly serviced that oil will get past the filter and begin to muck up your MAP sensor on the intake and those are not cheap. If it does not mess it up enough to throw a code, then it just affects the air fuel mixture which impacts your FE.
Wouldn't that be the MAF? Isn't the MAP located past the crankcase vent tube connecting to the intake? In this case the MAP is getting oiled already from the crankcase fumes going in the intake.
