Old 04-18-2008, 07:03 AM   #21 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Originally Posted by DifferentPointofView View Post
high load like towing and the like, WOT if you do that a lot, hauling lots of cargo and people.
When Under High Load Towing, like what diesel trucks are used for,that's when you need the best filtration, not the best air flow. Look at the K and N website at this link, #21:
http://knfilters.com/faq.htm#21
I wanna know where you get air filters for 8 bucks!
Try Rock Auto: http://www.rockauto.com/
I'm pretty sure it's more than that. I'll get my k & N box and take a look see
Originally Posted by http://knfilters.com/filtercharger.htm
The Importance of Oil
A K&N Air Filter is made of 4 to 6 layers of cotton gauze sandwiched between two epoxy-coated aluminum wire screens.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 05-05-2008, 11:40 PM   #22 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Honda Civic Sedan LX
90 day: 35.68 mpg (US)
Arrow
Guys, regardless of the filter brand and typer, you should NEVER reverse blow it out with compressed air. You can blow microscopic holes in the media and your filtering will be significantly diminished.
Curious if your air filtration system (not just the element, but the whole system) is doing its job? A UOA (Used Oil Analysis) might be able to tell by measuring the amount of silica and/or aluminum in a sample of used oil.
There are lots of places that provide this service (for $20-$25). Here's one I use:
http://www.blackstone-labs.com/gas_engines.html
--- Bror Jace
Old 05-06-2008, 01:12 AM   #23 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
There is only one draw back to using K&N filters or re-usable filters that require oil. And that is the oil. If improperly serviced that oil will get past the filter and begin to muck up your MAP sensor on the intake and those are not cheap. If it does not mess it up enough to throw a code, then it just affects the air fuel mixture which impacts your FE.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-06-2008, 05:52 AM   #24 (permalink)
A quick update...
There is a filter available locally which rinses out in water.
The company is Australian and has been in the exhaust business for decades.
Details at the link below:
http://www.lukey.com.au/default.asp?...ONTENT&sid=268
Haven't tried one yet but it on the "to do" list.
Thanks again to all who added their comments.
Cheers , Pete.
Old 05-06-2008, 08:03 AM   #25 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
On the TDI, you don't even take a look at the filter to see if you need to change it as they have one time compressible seals. Once you open that airbox, it's too late to turn back.
Wouldn't that be the MAF? Isn't the MAP located past the crankcase vent tube connecting to the intake? In this case the MAP is getting oiled already from the crankcase fumes going in the intake.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 05-06-2008, 09:46 PM   #26 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I use Baldwin Filters on everything I drive and also work on the heavy duty diesel trucks at work. Our business relies on quality and that is why we use Baldwin filters.
GeoMetroforum.com - got mpg?
Old 05-07-2008, 04:40 PM   #27 (permalink)
Try Rock Auto: http://www.rockauto.com/[/QUOTE]
Okay, I just spent a little time to check this place out and
Not to be redundant but that place rocks!
Parts not only for my car but for rare cars like TVR and Hillman?
Seriously I think they have a new customer.
On topic, just replace the filter because it is cheaper in the long run
and somewhere down the time line we will work out how to recycle
the damn things.
Hmmm, a new business opportunity perhaps?
Old 05-09-2008, 09:16 PM   #28 (permalink)
Some quick numbers on the Lukey filter but note the apply only to the
local ( Australian ) market.
Standard GM pleated paper $32.00
RYCO pleated paper $22.00
Lukey washable $90.00
K&N (oil is extra) $111.00
All for the same car on the same day , tax included.
Interesting , Pete.
Old 05-10-2008, 10:28 PM   #29 (permalink)
$90.00
Just how rarely are you changing your paper filter to justify spending 90 dollars on a reusable one.
Let's see, for me I would have to use at least 10 paper filters to equal the expense of one lukey washable filter. I don't see the economic upside to this.
But then I'm just a Jerk, so what do I know.
Old 05-11-2008, 12:47 AM   #30 (permalink)
Pushrod - '02 Chevrolet Cavalier
Attempting to reuse a paper filter borders on the insane. They are dirt cheap and are responsible for protecting something very expensive. When their service life is over, put them in the trash and buy another. You won't be saving any trees when your engine block has to be melted down because you spun a bearing.
That being said, I am a fan of Purolator's blue oiled paper filters.
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 63 03-22-2019 09:53 AM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
reuseable drop in air filters? Chris D. EcoModding Central 36 04-09-2008 05:04 PM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
