Old 05-09-2011, 12:48 AM   #272 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
^ Bearing play, that must be it.
I referenced the book and that's what it mentioned -- "slight play in the wheel bearings..."
I'm not sure about 4-wheel discs -- more aggressive cornering (on/off ramp?)
Anyways, I'd like to try the technique, but my RR rotor is really warped, but it's too thin to turn -- It seems to heat up after a while and the rubbing noise dissipates, but I know the rest are in less-than-flat condition as well (I'm too cheap to replace it just yet). Another discussion...
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
