Old 05-15-2011, 01:31 PM   #1 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Rear deck/trunk extension instead of Kammback
I have been reading some old posts on this site (search function). I came across this post but no satisfactory discussion of it. So I want to repost the statement and start a new thread. A kammback on a coupe like mine tends to undermine visibility and trunk access. Would a truck/deck extension work as an alternative to a kammback? Here's the quote:
"Your cheap fix, is to create a rear deck spoiler which extends rearward,and upward,no steeper than 30-degrees from horizontal,until it intersects the line of the template. That will give you a locked vortex which the air above will skim over as if the car was more like the teardrop. If the spoiler is steeper,you'll start inducing downforce which is induced- drag,and that will cost you at the gas pump."
james
