Old 05-18-2011, 04:28 PM   #25 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by minAirForce View Post
Where you get your plastic plugs? Those things are expensive in the auto stores
If that question is directed to me, I just drove the roofing screws into existing plugs in the VW underbody, didn't even pre-drill. Make sure the leading edge is fastened securely and no problems with the rest.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
