Old 05-01-2011, 10:41 AM   #21 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Nice work! Looks like a politicians race car now underneath. My question is, how much of a difference did it make? Could a mod like this cut down on road noise too?
It is not scientific since I can't really do back to back testing of the belly pan. But there is a trip I regularly take where my previous best mpg was about 55 with careful driving and I got into the low 60s after the belly pan, on the Scanguage. I didn't really notice any difference in noise though.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 05-01-2011, 04:34 PM   #22 (permalink)
Exalta-STA's Avatar
It'd be great if you have a template/trace out of your undertray :-)
Old 05-18-2011, 04:04 PM   #23 (permalink)
I've Been AeroHauled
Where you get your plastic plugs? Those things are expensive in the auto stores
Old 05-18-2011, 04:06 PM   #24 (permalink)
Also, be careful about how you fasten your copper tubes. Galvanic corrosion will rust your car.
Old 05-18-2011, 04:28 PM   #25 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
If that question is directed to me, I just drove the roofing screws into existing plugs in the VW underbody, didn't even pre-drill. Make sure the leading edge is fastened securely and no problems with the rest.
TDi=fast frugal fun
Old 05-18-2011, 04:29 PM   #26 (permalink)
how you mount these panels? did you have to drill holes in the body?
Old 05-18-2011, 06:49 PM   #27 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
http://ecomodder.com/forum/member-co...mg-0134sm.html
If you look carefully at this "before" photo you can see a round plastic plug just to the left of the catalytic converter and a couple more on the frame type reinforcements (look where the fuel line snakes around).
This photo shows what I used to attach it. NO new holes were drilled into the sheetmetal.http://ecomodder.com/forum/member-co...-img-0142.html
TDi=fast frugal fun
Old 05-21-2011, 02:13 PM   #28 (permalink)
VW GOLF - '96 Volkwagen Golf MK3 GL
90 day: 50.21 mpg (US)
Commute scoot - '95 Suzuki AE50 Style
Last 3: 70.4 mpg (US)
The German - '99 Mercedes W202 C200 Classic
90 day: 27.65 mpg (US)
Undertray Results
Hi guys,
Have finally made my way through 87.5 litres of various flavours of diesel (83% Bio 17% Dino) with my undertray on, and I'm showing a 4mpg (uk) increase from 58 to 62mpg. That brings me into the 50's in US mpg.
Initial observations:
  • Noise levels seem higher (tho this could be my hard tyres);
  • I can hear more 'wind noise' around the A pillars (perhaps the road noise has dropped so I can now hear this);
  • This is only the first full tank with the tray on, and it is pretty roughly built;
  • I have been driving VERY VERY slowly tho I was doing that last tank too;
  • Due to the price of fuel in the UK (about $2.28 per litre), the motorway network has slowed down, with many lorries now limited to 50 by their owners; and
  • I need to tune the exit angle, it is way too steep as it is.
I have also just scored a scrap garage door, so will remake my undertray from Sheet Metal to make it smoother.
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
Metro undertray / belly pan MetroMPG Aerodynamics 47 03-13-2014 06:13 PM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 08:50 AM
Some small aero tweaks - VW Golf Mk3 1.9 Turbo Diesel sallen Aerodynamics 0 03-28-2010 08:33 AM
Mirror Swap - VW Golf MK3 1.9 Turbo Diesel sallen Aerodynamics 2 03-28-2010 06:34 AM
Wanted (1st gen VW turbo diesel) 3lr For Sale 19 10-28-2008 04:28 AM
