Old 05-18-2011, 05:49 PM   #27 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by minAirForce View Post
how you mount these panels? did you have to drill holes in the body?
http://ecomodder.com/forum/member-co...mg-0134sm.html
If you look carefully at this "before" photo you can see a round plastic plug just to the left of the catalytic converter and a couple more on the frame type reinforcements (look where the fuel line snakes around).
This photo shows what I used to attach it. NO new holes were drilled into the sheetmetal.http://ecomodder.com/forum/member-co...-img-0142.html
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
