Old 05-19-2011, 03:16 PM   #5 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Bill in Houston View Post
Eventually I will also add a front undertray to smooth out that section.
I would try to follow Aerohead's suggestions. If you do the belly pan eventually, I would sure do the front undertray before working your way toward the back. You don't want to scoop a lot of air up between your belly pan and chassis. If air coming from the front of the car is turbulent it will negate most of the gains of a smooth bellypan farther back.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
